What is Flow breakout board raw frame FPS?
rubzir
Post by rubzir » Tue Jan 21, 2020 10:28 am
I saw that the Flow breakout board Arduino library supports raw frame buffer capture (get the raw image that the sensor sees- bit by bit)
I couldn't any information about the theoretical max raw frames per seconds (FPS) of PMW3901 using the SPI.
Rub
Re: What is Flow breakout board raw frame FPS?
Post by kimberly » Thu Jan 23, 2020 9:56 am
So to understand exactly, you would like to capture the actual image?
I wouldn't know exactly what the frame rate is exactly to be honest. It has been a very recent pull request so you can check it out here: https://github.com/bitcraze/Bitcraze_PMW3901/pull/9. @Arnaud tried it out so I will ask him next week if he was able to measure this as well.
