Optical Flow signal delay
Posted: Tue Nov 19, 2019 10:11 pm
by bobby183
I have been playing around with the PMW3901 optical flow sensor for a little while, and I noticed something I could not find any reference to anywhere else. I was trying to validate the gyroscopic compensation for rotational velocity readings, when I noticed that the gyro signal and the optical flow readings were delayed by about 100 milliseconds, has anyone else noticed this? I will try to post a graph of the sensor readings later on. Thanks
Re: Optical Flow signal delay
Posted: Wed Nov 20, 2019 12:41 pm
by arnaud
I do not think this delay has been measured by us before, if it is that delayed it is very interesting because it could cause some oscillation that sometime happens with the flow! It would be great if you could post some more info about how your measured the delay.
Posted: Wed Nov 20, 2019 3:09 pm
by bobby183
Here's an example comparing the gyroscope and velocity sensor:
I am rotating the board back and forth, I would expect the angular velocity and the velocity read by the sensor to be aligned, but as you can see the velocity sensor is ever so slightly lagging behind the gyroscope which culminates in very poor compensation for angular rotation. When I delay the gyroscope (and distance) measurements by give or take 100 milliseconds the compensation works much better and only measures the lateral velocity. I have done these tests with the following modules and have had the exact same, and in some cases even more worse, results:
CX-OF: https://www.aliexpress.com/item/32837432356.html
Another serial module: https://www.aliexpress.com/item/3300200 ... 4c4dA6Kmg0
I2C module: https://www.tindie.com/products/onehors ... ow-sensor/
Posted: Thu Nov 21, 2019 11:49 am
by arnaud
Ho, so you are not using the flow deck. Are you attaching these modules to a Crazyflie and if so what driver are you using on the Crazyflie to interface them?
Very interesting measurement nonetheless. This looks like something that we should account for in our EFK implementation.
Posted: Thu Nov 21, 2019 2:46 pm
by bobby183
No I am not using the flow deck, however the data I collected and plotted is the scaled raw output of the sensors before any fusion or processing, the driver I used to interface with the SPI module is the Bitcraze one:
https://github.com/bitcraze/Bitcraze_PMW3901
The results should be repeatable using any board with the PWM3901 sensor; it seems like it's the sensor itself that has this issue rather than a particular board. I was surprised to see the same (or worse) delay with the SPI module when compared to UART; it would be great if someone else could replicate and confirm these results.
