[RESOLVED] radio lost connection after actuate the 5th motor
zhanghaijason
Post by zhanghaijason »
I am using Crazyflie to do a project. I have a fifth motor used to actuate some mechanism on Crazyflie. It worked before, but now it loses connection everytime after I apply power to the motor driver, it lost connection.
The process is as follows:
1. fly cf to a specific location and stop there
2. actuate 5th motor.
3. Lost connection
if I directly actuate 5th motor without flying it, connection doesm't lost.
One month ago I did the above procedures many times, everthing was good. But now it starts to lose connection.
Re: radio lost connection after actuate the 5th motor
Where is the 5th motor located? Is it near the antenna?
It is indeed a bit weird that it does not lose connection if you do not fly it and actuate the 5th engine. Are you sure it is not drawing too much current? Flying 4 motors is already takes up a lot of power for the tiny crazyflie ;)
zhanghaijason
kimberly wrote: ↑Wed Jul 31, 2019 12:13 pm Hi!
I used another CF and it works well. I guess the receiver on the old CF was kind of broken. Thanks for your reply.
