Automatic propeller test
crazyminecuber
Post by crazyminecuber » Thu Jul 25, 2019 10:00 am
I want to imitate the propeller test in the console in cfclient. However i want to be able to write a python script that does that. I thought it would be as easy as setting that parameter like this.
scf.cf.param.set_value('health.startPropTest', '1')
However nothing appear to happen. I have digged a little bit in the code for cfclient but have been unable to find something useful. Anyone got any ideas?
Re: Automatic propeller test
Post by kimberly » Fri Jul 26, 2019 7:50 am
Have you tried something like this (change the URI to your crazyflies' URI):
import time
import logging
import cflib.crtp
from cflib.crazyflie.param import Param
URI = 'radio://0/56/2M/E7E7E7E706'
if __name__ == '__main__':
       scf.cf.param.request_update_of_all_params()
       time.sleep(5)
This seems to work for me to initialize the motor health test.
crazyminecuber
Post by crazyminecuber » Mon Jul 29, 2019 7:25 am
Thanks a lot! It did not work immediately for me but if Iadded a delay between the parameter-update and parameter-set, it works. Do you know of a way to print the same data that the real prop test does i.e.
STAB: Acc noise floor variance X+Y:0.005075, (Z:0.002433)
STAB: Motor M1 variance X+Y:0.159692 (Z:0.678977)
STAB: Motor M2 variance X+Y:3.666144 (Z:16.641471)
STAB: Motor M3 variance X+Y:2.062783 (Z:2.178436)
STAB: Motor M4 variance X+Y:1.124510 (Z:0.959228)
STAB: Propeller test on M2 [FAIL]. low: 0.0, high: 2.50, measured: 3.66
Post by kristoffer » Tue Jul 30, 2019 8:52 am
To get the text for the console you would have to set up the console logging which is a bit tricky. I would recommend to take a look in the python client source code if you are interested in this.
Otherwise I have added log variables that you can use to get the result of the test, see https://github.com/bitcraze/crazyflie-f ... issues/448
Simply set up a subscription to health.motorPass and check bits 0-3. 0=FAIL, 1=OK
When the test is finished, bit 7 is set to 1
The accelerometer variances are available in motorVarXM1, motorVarYM1, motorVarXM2 and so on
