cannot flash firmware - cannot connect to bootloader
Posted: Sun Jul 14, 2019 8:30 am
hi
I cannot connect to bootloader to flash firmware.
I can connect to the drone in FW mode - (via USB)
using "make cload" from the VM it says --
using cfloader it just says "cannot connect to bootloader"
I don't know how to flash firmware via USB... if you have any link to do it
thanks
SYS: Build 0:a1d5aac6f3e6 (2019.02) MODIFIED
SYS: I am 0x2035355237485008004D0039 and I have 1024KB of flash!
CFGBLK: v1, verification [OK]
DECK_DRIVERS: Found 16 drivers
DECK_INFO: Found 2 deck memories.
DECK_CORE: 2 deck enumerated
ZR2: Z-down sensor [OK]
MPU9250 I2C connection [OK].
AK8963 I2C connection [OK].
LPS25H I2C connection [OK].
ESTIMATOR: Using estimator 2
CONTROLLER: Using controller 1
EEPROM: I2C connection [OK].
AK8963: Self test [OK].
MR: Init front sensor [OK]
MR: Init back sensor [OK]
MR: Init up sensor [OK]
MR: Init left sensor [OK]
MR: Init right sensor [OK]
DECK_CORE: Deck 0 test [OK].
DECK_CORE: Deck 1 test [OK].
SYS: Free heap: 8672 bytes
Restart the Crazyflie you want to bootload in the next
10 seconds ...
File "/home/bitcraze/projects/crazyflie-clients-python/src/cfloader/__init__.py", line 150, in main
if bl.start_bootloader(warm_boot=False):
File "/home/bitcraze/.local/lib/python3.6/site-packages/cflib/bootloader/__init__.py", line 112, in start_bootloader
self._cload.request_info_update(TargetTypes.NRF51)
File "/home/bitcraze/.local/lib/python3.6/site-packages/cflib/bootloader/cloader.py", line 246, in request_info_update
return self.targets[target_id]
KeyError: 254
254I don't know how to flash firmware via USB... if you have any link to do it
thanks
