Firmware development in Windows
matejkarasek
Post by matejkarasek » Tue Jul 09, 2019 12:13 pm
Hi everyone,
As a newbie to the Bitcraze community, I am setting things up for firmware development...
What is the best option for firmware development (preferably natively) on Windows 10 (and/or 7)?
I found some options on the bitcraze&github wikis but have been told the info might be outdated...
https://github.com/bitcraze/crazyflie-firmware
https://wiki.bitcraze.io/doc:crazyflie:dev:env:windows
Combining these two tutorials I could get the make running via Cygwin, but the build is very slow (and I am getting some build errors when building for the Roadrunner board, CF2 builds fine).
Is there anyone with some recent experience?
Thanks!
Matej
Re: Firmware development in Windows
Post by kimberly » Tue Jul 09, 2019 2:21 pm
Tricky and valid question :)
@theseankelly ? you work a lot with windows native install development? Could you help Matej out with this?
matejkarasek
Post by matejkarasek » Wed Jul 10, 2019 3:53 pm
Just an update:
Following the Cygwin path, I am now able to make and generate the .bin, .hex and .elf files.
make cload gives me the following error after "Restart the Crazyflie you want to bootload in the next 10 seconds ...":
Exception: Cannot find a Crazyradio Dongle
Can the Crazyradio dongle be accessed from Cygwin? (the Windows app and the VM can access it, I use the libusb0 driver)
Or is there another way how to flash the firmware if I already have the bin, hex and elf files?
Thanks for any advice...
Matej
PS:
To get this working, I have installed Cygwin with the following packages:
Further, I have cloned and installed:
crazyflie-firmware
crazyflie-lib-python
crazyflie-clients-python
