Max Distance Ranging
jdiep
Post by jdiep » Wed Jun 26, 2019 11:34 pm
I would like to use the LPS to positioning a drone outdoor on a football field. Does someone knows what the max ranging capacity of the LPS nodes are? And also are there any research done considering optimal anchor placement?
Thanks in advance!
Re: Max Distance Ranging
Post by kimberly » Fri Jun 28, 2019 11:04 am
Did you check out this wiki page yet? https://wiki.bitcraze.io/misc:investiga ... -max-range ;)
jdiep
Post by jdiep » Fri Jun 28, 2019 10:46 pm
perfect, havent seen that yet. thanks a lot, cheers!
jdiep
Post by jdiep » Wed Jul 10, 2019 7:35 am
I did a few tests myself outdoor on a race track. The furthest distance I was able to get a continuous stream of range data was approximately 25m at max power. However, your investigation lists a max range of 50-70m. How is this difference possible?
