implementing collision avoidance in FW
wydmynd
Post by wydmynd » Tue Jun 11, 2019 2:51 pm
Hello
are you aware of anyone who implemented collision avoidance in firmware?
I am using the mellinger controller so I would prefer to implement on it.
I tried running collision avoidance routine on the PC but sometimes it has lag or communication glitches and doesn't work well.
even pointers on any of these sub-tasks -
1. sample a log variable (ranges from range deck)
2. create a "task" that checks every X ms , or maybe implement this on the ranger deck driver itself?
3. create a message for the mellinger controller with the new setpoint if collision is detected (I would like to send a simpler command, but from my experience, if a low-level command is sent while high-level controller is running, the localization of the flow deck will stop working for the duration of the command)
any samples, references to articles or posts where people post new functions in CF firmware will be very welcome.
Re: implementing collision avoidance in FW
Post by arnaud » Wed Jun 12, 2019 7:25 am
We have a version of the multiranger 'push' demo that works in the firmware, this is a simple form of obstacle avoidance. We also have the ICRA2019 demo that used the high-level-commander from the firmware.
So for 1) and 2) you can look at the firmware-implemented push demo: https://github.com/bitcraze/crazyflie-f ... src/push.c. This is implemented as a deck driver, as it is one of the easiest way to add a task running in the Crazyflie (ie. it is the way that requires the minimum amount of changes). There is an API to read log variables from within the firmware.
For 3) you can look at our ICRA2019 demo, in this demo we send commands to the high level commander from the Crazyflie firmware: https://github.com/bitcraze/crazyflie-f ... app.c#L325. This branch was more of an experimentation since it is not using the deck driver methods, an app.c file has been added and a couple of function have been added to control the high-level commander from within the firmware. If you want to use the same approach you can start from the ICRA2019 branch. We are planning to look at making an easy-to-use app layer with documented public C API a bit later in the summer and the ICRA demo was a way to play with the idea.
wydmynd
Post by wydmynd » Thu Jun 13, 2019 1:49 pm
thank you very much! I have searched for few hours and found no similar code on the web, academic articles or in the forums.
I will try to implement using a "virtual deck" method first, as I assume it has lower chance of creating bugs.
report here when I have progress
wydmynd
Post by wydmynd » Tue Jun 18, 2019 9:57 am
Hi again!
I tried to follow the instructions. for the first method (push.c as a "virtual deck")
first I tried cloning the proper branch of crazyflie-experimental and building it, but there were many errors.
So I started from a fresh VM ,
added only the push.c file in the deck/driver/src folder
added the compile flag to the makefile -
PROJ_OBJ += push.o
made a copy of the config.mk.example and named it config.mk
added the lines to config.mk -
CFLAGS += -DDECK_FORCE=bcPush
DEBUG=1
and then -
make clean
make all
make cload
the message "CC push.o" appears in the make history ..
when connecting I get
SYS: Build 0:a203d748e139 (2018.12) MODIFIED
SYS: I am 0x30343631303747100031002D and I have 1024KB of flash!
CFGBLK: v1, verification [OK]
DECK_DRIVERS: Found 17 drivers
DECK_DRIVERS: VID:PID 00:00 (bcRZR)
DECK_DRIVERS: VID:PID BC:01 (bcLedRing)
DECK_DRIVERS: VID:PID BC:04 (bcBuzzer)
DECK_DRIVERS: VID:PID BC:07 (bcGTGPS)
DECK_DRIVERS: VID:PID 00:00 (bcCPPM)
DECK_DRIVERS: VID:PID BC:08 (bcUSD)
DECK_DRIVERS: VID:PID BC:09 (bcZRanger)
DECK_DRIVERS: VID:PID BC:0E (bcZRanger2)
DECK_DRIVERS: VID:PID BC:06 (bcDWM1000)
DECK_DRIVERS: VID:PID BC:0A (bcFlow)
DECK_DRIVERS: VID:PID BC:0F (bcFlow2)
DECK_DRIVERS: VID:PID BC:0B (bcOA)
DECK_DRIVERS: VID:PID BC:0C (bcMultiranger)
DECK_DRIVERS: VID:PID 00:00 (bcLH8)
DECK_DRIVERS: VID:PID 00:00 (bcPush)
DECK_DRIVERS: VID:PID BC:FF (bcExpTest)
DECK_DRIVERS: VID:PID BC:FE (bcExpTestRR)
DECK_INFO: Found 2 deck memories.
DECK_INFO: Enumerating deck 0
DECK_INFO: Deck BC:0F bcFlow2 (Rev. A)
DECK_INFO: Used pin: 0000000C
DECK_INFO: Driver implements: [ init test ]
DECK_INFO: Enumerating deck 1
DECK_INFO: Deck BC:0C bcMultiranger (Rev. E)
DECK_INFO: compile-time forced driver bcPush added
DECK_CORE: 3 deck enumerated
DECK_CORE: Calling INIT from driver bcFlow2 for deck 0
ZR2: Z-down sensor [OK]
DECK_CORE: Calling INIT from driver bcMultiranger for deck 1
DECK_CORE: Calling INIT from driver bcPush for deck 2
MPU9250 I2C connection [OK].
AK8963 I2C connection [OK].
LPS25H I2C connection [OK].
ESTIMATOR: Using estimator 2
CONTROLLER: Using controller 1
EEPROM: I2C connection [OK].
AK8963: Self test [OK].
DECK_CORE: Deck 0 test [OK].
MR: Init front sensor [OK]
MR: Init back sensor [OK]
MR: Init up sensor [OK]
MR: Init left sensor [OK]
MR: Init right sensor [OK]
DECK_CORE: Deck 1 test [OK].
DECK_CORE: Deck 2 test [OK].
SYS: Free heap: 7360 bytes
Waiting for activation ...
I try to takeoff using high level controller , the drone does not take off. after stop command is sent, two red LEDs turn on.
can you suggest the reason?
I understand the push.c code is sending hover commands, so maybe there is a conflict with the high level controller?
thanks
Post by arnaud » Wed Jun 19, 2019 9:18 am
From what you are describing you successfuly managed to run the push demo in your firmware, now if you have both a flow and a multiranger deck installed you will be able to have the Crazyflie taking off by putting your hand close to the top of the multiranger deck. To achieve this functionality the push.c file controls the Crazyflie and you should not expect to be able to control it any other way.
If you want to be able to both control the Crazyflie from outside and having it avoiding obstacle using the high level controller, you have to modify push.c to send high-level commands and not low level commands as it is the case right now.
The low level set point system implemented in the crazyflie is designed to handle multiple sources with priority however I do not think the high-level commander is designed that way. This means that if you want to send high-level commands both from the ground and from withing the firmware you have to be a bit careful about how things are implemented and if it would work at all (I think that as long as you are only using GOTO commands, you should be safe for instance).
The best might be to pass all commands through your own code: send all commands to your code and have your code deciding what commands needs to be sent to the high-level commander, this way you do not risk conflicts between the firmware and the ground commands, and you can implement higher level functionalities like going around obstacles to reach the wanted setpoint.
wydmynd
Post by wydmynd » Wed Jun 19, 2019 1:23 pm
Thanks! it works! I was focused on the compiling and running I missed this functionality in the code.
regarding your comment on high level control, from my experience you can send low level set points to a drone running high level controller, but after the command finishes executing the drone will return to the starting point where the command was issued. I guess something with the state estimate is not being updated.
This is actually too bad , because now if I am running a high level controller and have a collision (for example front sensor) I need to calculate the angle of the front sensor in world coordinates (the drone may rotated) and send a position setpoint in that direction.
I plan to do this by sampling the stateestimate log variable, and then doing the transformation.
Regarding your comment on conflicts between the firmware and the ground commands, I need to find a function that can "sample" the high level setpoints being sent to the drone. currently the method in your code can sample log variables (logGetUint)
I will be very thankful if you can point me to code in the experimental repo that I can analyze
regards
wydmynd
Post by wydmynd » Wed Jun 19, 2019 2:36 pm
I found crtpCommanderHighLevelGetSetpoint
https://github.com/bitcraze/crazyflie-f ... nder.c#L87
I assume it allows polling the current go_to setpoint. but if I want to pass all commands through my code I will have to modify the highlevelcommander
-- insert some code between the polling of the setpoint section and the section where it is sent to the planner
If you have any thoughts/comments I will be glad to hear..
