I was using an older VM version (ubuntu 14) and was forcing a deck initialization on the CF2. Everything worked perfectly fine, but the eclipse itself was giving me a headache due to a few bugs in the IDE.
To solve the eclipse issues, I was forced to download and use the newer bitcraze VM version, and have updated all projects.
After doing so, I tried using the bcSequence example (autonomously flying 8 figure) to make sure everything still works well. I have done everything exactly as written here:
viewtopic.php?f=6&t=2648&p=13352&hilit=demo#p13352
I can see the deck sequence.o being compiled, however, the CF2 will not perform the sequence. My thoughts are that the deck is compiled but not being forced to initialize.
I have added the following line to config.mk:
CFLAGS += -DDECK_FORCE=bcSequenceCode: Select all
PROJ_OBJ += sequence.oIf not, any idea what other possible reason can cause this behavior?
Thanks in advance,
Roei
