Bitcraze VM 0.3
Bitcraze VM 0.3
We have published a new version of our virtual machine (0.3) and updated the instructions on the wiki. If you try the new version it would be great to get some feedback! Is something missing, not working or do you have any suggestions for improvements? The delay between version 0.2 and 0.3 was pretty long, so our goal is to release version 0.4 after a few weeks of testing.
Here's a list of what's in the new version that can be downloaded here.
/Marcus
/Marcus
Re: Bitcraze VM 0.3
Thanks for developing the VM. Is there a way to migrate user settings from 0.2 to the newer VM version?
Re: Bitcraze VM 0.3
Unfortunately I don't know of any good way of doing this if you have installed new applications etc. But to move the files from one VM to another you can activate the Folder Sharing option in both the new and the old VM and then you can copy you changes to/from the host OS. You could move the all of the files in the home folder but then you have to make sure not to overwrite files in the new VM (like /home/bitcraze/.bashrc).
Re: Bitcraze VM 0.3
Thanks, but since I'm new to Linux, merging the VM versions by copying the home folder seems to exceed my skills.
I'll simply do some installation and configuration again. That's ok.
Re: Bitcraze VM 0.3
1. Hmm, seems like Eclipse isn't preconfigured correctly. I can't see any projects in the "projects explorer window". How to bring them back?
2. If I cloned the firmware in TortoiseHG to start my own development version, how can I bring the clone into Eclipse? Sorry for the dumb questions...
Re: Bitcraze VM 0.3
Mega tells me Temporarily Unavailable for the file
hopefully until my jtag connector cable arrives at thuesday, it will be available for download
Re: Bitcraze VM 0.3
Hmm, that is strange, maybe we used to much bandwidth or Mega is having problems. There is a torrent available as well under the download section in the wiki.
Re: Bitcraze VM 0.3
The download from Mega turns out to be limited to 6 simultaneous downloads so if you can then use the torrent instead.phiamo wrote:Mega tells me Temporarily Unavailable for the filehopefully until my jtag connector cable arrives at thuesday, it will be available for download
Re: Bitcraze VM 0.3
Are you using version 0.3? I can see the two projects in the Project Explorer.alex wrote:1. Hmm, seems like Eclipse isn't preconfigured correctly. I can't see any projects in the "projects explorer window". How to bring them back?
You can import a new project by selecting new and import in the Project Exploreralex wrote:2. If I cloned the firmware in TortoiseHG to start my own development version, how can I bring the clone into Eclipse? Sorry for the dumb questions...
Re: Bitcraze VM 0.3
We created a new project on Bitbucket to track issues and improvements for the Bitcraze VM. So if you find any issues or have ideas for improvements just drop by and create a new issue on the tracker.
