Setpoint handling in Crazyflie firmware
Andy
Post by Andy » Mon Apr 15, 2019 2:14 am
I would like to try my own high-level controller on the Crazyflie. This controller outputs reference values for (roll, pitch, yaw rate, thrust) that should be sent to the Crazyflie as a setpoint. I saw that in the Commander.py class in the crazyflie_lib there are functions for sending setpoints of the form (roll, pitch, yaw, thrust) or (roll, pitch, yawrate, zdistance), but not the one I need. However, given that the reference values are controlled by different functions, I believe that I can easily modify the firmware according to my system.
The question is, where are the setpoints handled in the CF firmware and what do I need to change there?
Cheers
Andy
Re: Setpoint handling in Crazyflie firmware
Post by Andy » Mon Apr 15, 2019 11:40 pm
Maybe a bit more precise, where in the firmware does the type of setpoint sent to the Crazyflie get classified and how are the setpoints processed differently according to the setpoint type?
Post by tobias » Tue Apr 16, 2019 9:17 am
The setpoint architecture is a bit messy (because of backward compatibility) but adding a setpoint type is quite straight forward in crtp_commander_generic.c.
