Setpoint handling in Crazyflie firmware
Andy
Post by Andy » Mon Apr 15, 2019 2:14 am
I would like to try my own high-level controller on the Crazyflie. This controller outputs reference values for (roll, pitch, yaw rate, thrust) that should be sent to the Crazyflie as a setpoint. I saw that in the Commander.py class in the crazyflie_lib there are functions for sending setpoints of the form (roll, pitch, yaw, thrust) or (roll, pitch, yawrate, zdistance), but not the one I need. However, given that the reference values are controlled by different functions, I believe that I can easily modify the firmware according to my system.
The question is, where are the setpoints handled in the CF firmware and what do I need to change there?
Cheers
Andy
Re: Setpoint handling in Crazyflie firmware
Post by Andy » Mon Apr 15, 2019 11:40 pm
Maybe a bit more precise, where in the firmware does the type of setpoint sent to the Crazyflie get classified and how are the setpoints processed differently according to the setpoint type?
Post by tobias » Tue Apr 16, 2019 9:17 am
The setpoint architecture is a bit messy (because of backward compatibility) but adding a setpoint type is quite straight forward in crtp_commander_generic.c.
sample
Post by sample » Fri May 03, 2019 11:08 am
We have a similar question.
We are using lighthouse positioning, ROS Kinetic and CrazySwarm ROS. We would like to write a publisher that publishes zDistance type of setpoints (roll/pitch/yawrate/z_positon). How do we accomplish this? What are the necessary firmware changes? Have you got an example of a similar project?
One of the alternatives is using cmdFullState, but we are not sure how to modify it so it doesn't require setpoints we are not generating.
Thank you!
Post by arnaud » Mon May 06, 2019 9:51 am
There should be no modification needed in Firmware since this setpoint is already handled by the Crazyflie firmware.
You need to add the serpoint to the Crazyflie ROS driver if it is not handled yet. I have never done so but a quick look shows that a function should be added in Crazyflie-cpp: https://github.com/whoenig/crazyflie_cp ... #L169-L219 and the functionality needs to be added to the crazyflie_server part of the ROS crazyflie driver: https://github.com/whoenig/crazyflie_ro ... r.cpp#L219 and https://github.com/whoenig/crazyflie_ro ... r.cpp#L379.
sample
Post by sample » Wed May 08, 2019 1:06 pm
Thank you Arnaud, adding these changes to crazyswarm server solved our problem. There is just one thing.. it seems to work with PID but not with Mellinger controller. Do you know does the implementation of the Mellinger controller allow zDistance type of setpoints (roll/pitch/yawrate/z_positon)?
Post by arnaud » Wed May 08, 2019 1:28 pm
I am not surprised it does not work with mellinger: I do not know much details about the Melinger controller but my understanding is that you need to provide much more data to get it to work (ie. wanted position/velocity/acceleration). When using the zDistance setpoint you are only providing for x/y velocity and Z position. I think Mellinger can work with the full state setpoint: https://github.com/bitcraze/crazyflie-f ... ric.c#L299
sample
Post by sample » Thu May 09, 2019 8:27 am
Yeah, that's what we thought.
Thank you for your help!
