Problem with sending commands through ZMQ server (port 2004)
Mhdzahd93
Post by Mhdzahd93 » Thu Apr 11, 2019 1:58 pm
I am working on controlling the position of the Crazyflie 2.0 (roll, pitch, yaw, and thrust) in Matlab using the ZMQ server.
I am able to scan, connect, and log with the ZMQ server. However, when I try to send roll, pitch, yaw, and thrust commands to the crazyflie, nothing happens. I am the 2004 port for sending the commands. When I send wrong messages the cfzmq shows a response but whenever I send the correct form of a message it does not do anything.
Do I need to set a parameter first before start sending the commands?
Thanks for your time.
Re: Problem with sending commands through ZMQ server (port 2004)
Post by tobias » Wed Apr 17, 2019 8:52 am
It is probably because there is a thrust lock that requires sending 0 thurst once.
