I used this tutorial to turn my Raspberry Pi into a base station:
http://wiki.bitcraze.se/projects:crazyf ... rasberrypi
Everything works perfectly, but i'm used to flying in "x" mode, and I have been unable to enable this mode. I have tried changing “client_side_xmode” to “true” in “crazyflie-pc-client/lib/cfclient/configs/config.json”, but that doesn't seem to change it. Here's the contents of that config file:
"writable" : {
"input_device": "",
"link_uri": "",
"flightmode": "Advanced",
"open_tabs": "Flight Control",
"trim_pitch": 0.0,
"slew_limit": 45,
"slew_rate": 30,
"trim_roll": 0.0,
"max_thrust": 80,
"min_thrust": 25,
"max_yaw": 200,
"max_rp": 30,
"client_side_xmode": true,
"device_config_mapping": {}
"read-only" : {
"normal_slew_limit": 45,
"normal_slew_rate": 30,
"normal_max_thrust": 80,
"normal_min_thrust": 25,
"normal_max_yaw": 200,
"normal_max_rp": 30,
"default_cf_channel": 10,
"default_cf_speed": 0,
"default_cf_trim": 0
self.helper.cf.commander.set_client_xmode(checked)Which corresponds to this in "crazyflie-pc-client/lib/cflib/crazyflie/commander.py":
def set_client_xmode(self, enabled):
Enable/disable the client side X-mode. When enabled this recalculates
the setpoints before sending them to the Crazyflie.
self._x_mode = enabled
