Can't get motion commander example to work
jalalirs
Post by jalalirs »
Hello all,
I have been trying to run the motion commander example https://github.com/bitcraze/crazyflie-l ... er_demo.py but no success. I managed to run the ramp.py but not any example with SyncCrazyflie. Astonishingly, the scripts run ok with no error but the quadcopter is never triggered. I have tried to debug the code but I couldn't find any bug. I put print statement everywhere in the code, including the send_packet function. Everything seems fine and the numbers look reasonable. Can you please advice
I am using Crazyflie 2 with a flow deck. I am running python3.7 on Mac
I attached the logs
Regards,
logs.txt
(6.74 KiB) Downloaded 638 times
jalalirs
Re: Can't get motion commander example to work
Post by jalalirs »
Waw. Right after I posted this question, I was able to solve it by updating the framework of the crazyflie using the iphone app. This solved the problem
It is most likely that the firmware in your crazyflie was too old for these example. The examples assumes you are running the latest version of the Crazyflie firmware. Since I assume you have a Crazyradio, updating the firmware using the PC client is much quicker than using your iphone, see the getting started guide for instruction: https://www.bitcraze.io/getting-started ... #latest-fw.
