Autonomous flight instability
Posted: Thu Mar 07, 2019 11:19 am
Using the ROS robotic operating system and the OPTITRACK infrared motion capture system for autonomous hovering of the aircraft, it was found that the aircraft was significantly offset towards the X-axis or Y-axis side and hit the laboratory's protective net. We used a number of aircraft to perform repeated experiments and found that only one aircraft was able to hover stably. The only difference between this aircraft is that the position of the motion capture system is different. We have modified the PID parameters, and the actual impact is small, and the take-off time has been extended. At the same time, we also ruled out the influence of the motive of the positioning system. Our team considered whether it was the effect of different centroid positions at the location of the markers. Need your help. Thank you
