Flow Deck - Reversed, Upwards instead of Downwards
I am hoping that there's a simple way to implement what I'm trying to do. I'd like to mount the flow deck on top of the drone and use the ceiling instead of the floor. In theory this should be very simple, but I don't know if there's an implementation for it with the Crazyflie. Any advice would be appreciated.
Re: Flow Deck - Reversed, Upwards instead of Downwards
One way of doing it is to connect wires between the connectors so you still can connect it the correct way.
