Hover instability
Discussions about technology in general
harriswang
Hover instability
Post by harriswang »
Autonomous hovering is performed using the optitrack motion capture system and the ros operating system, but the aircraft flies to the Y-axis or Z-axis side after take-off, which is a specific problem. thank you
Re: Hover instability
It could be that the crazyflie doesn't have any yaw information. It probably have to be started in the right direction for it to work properly.
harriswang
Hello, we have used a lot of aircraft to carry out experiments, but one aircraft is able to complete the stable hovering mission. The only difference between this aircraft is that the marking points recognized by the motion capture system are placed on the aircraft differently, is it not? Does the position of the center of mass affect the experiment? Thank you
The center of mass will off course affect performance, but it should not make the Crazyflie unable to hold a position setpoint unless you have a big out of center weight.
From your problem description it seems like the tracking is not working properly for the affected Crazyflies or that the position estimate is not sent correctly to the affected Crazyflie.
