I am fairly new to ROS and C++ so be gentle
Thank you.
EDIT: I have posted this into wrong subforum, please move it into Crazyflie Nano Quadcopter developer discussions. Thank you!
EDIT2: I have managed to publish roll/pitch/yawrate from the callback function cmdVelChanged in the crazyflie_server.cpp, but these values seem to be the same as the cmdVel values (position references). Does anyone know where to access inner loop references (roll, pitch, yaw)?
EDIT3: As whoenig stated here, these values are used in the older versions before the onboard controller was implemented. I have managed to retrieve needed data through logging in the CF Client.
