self checking
harriswang
self checking
Post by harriswang » Sat Oct 27, 2018 12:45 pm
when i connect the power supply,the cf cannot self check.and the guiding M2 is always bright,but others are not bright.what should i do?
thank u!
Re: self checking
Post by arnaud » Tue Oct 30, 2018 12:33 pm
Sounds like you need to re-flash your Crazyflie using the bootloader. If everything is blocked, the way to re-launch the bootloader is:
1) Disconnect the battery
2) Press the power button
3) Connect the battery while the button is pressed
4) As soon as the M2 Blue LED starts blinking, release the button
Now both blue LEDs should blink and if so you will be able to flash the Crazyflie using the Crazyflie client.
