I followed a tutorial shows how to control the 5th motor on CF. That tutorial adds two parameters in CF client to change the values. The parameter value should control PB5 and PB8's output (0 or 1). I successfully upload the firmware. However, when I cahnged the parameter, the output of PB8 and PB5 are always 0. I checked my code is the same with the tutorial. The tutorial was written about 1 year ago. And I updated the firmware to the lastest and modified it based on the tutorial. Is it possible that the new firmware conflicts with the tutorial? The tutorial uses pinsource2, timer5, GPIOA, PH8, PH5, pwm1 on PA2. The tutorial is attached.
CF does't responds to changed parameters
zhanghaijason
- Member
- Attachments
- pwmTutorial2.pdf
- (992.49 KiB) Downloaded 389 times
Re: CF does't responds to changed parameters
It is possible that something has broken during development. It is a lot to setup. Can you share your code, either on github or here?
zhanghaijason
- Member
Hi Tobias,
The code are attached.
motorsDriver.c
* motorsDriver.c
* Created on: Sep 20, 2018
* Author: bitcraze
#include <stdbool.h>
#include "stm32fxxx.h"
#include "motorsDriver.h"
// FreeRTOS includes
#include "FreeRTOS.h"
#include "task.h"
#define BASE_FREQ (328125)
static bool isInit=false;
// initialize output
void GPIOInit(){
GPIO_InitTypeDef GPIO_Struct;
// clocl setup
RCC_AHB1PeriphClockCmd(RCC_AHB1Periph_GPIOA, ENABLE);
// TIMER SETUP
GPIO_PinAFConfig(GPIOA, GPIO_PinSource2, GPIO_AF_TIM5);
GPIO_Struct.GPIO_Mode=GPIO_Mode_AF;
GPIO_Struct.GPIO_OType=GPIO_OType_PP;
GPIO_Struct.GPIO_Pin=GPIO_Pin_2;
GPIO_Struct.GPIO_PuPd=GPIO_PuPd_DOWN;
GPIO_Struct.GPIO_Speed=GPIO_Speed_2MHz;
// initialize GPIOA with setup config
GPIO_Init(GPIOA, &GPIO_Struct);
void timerInit(){
// Struct to initialize/configure TIM5
TIM_TimeBaseInitTypeDef TIM_TimeBaseStruct;
//clock
RCC_APB1PeriphClockCmd(RCC_APB1Periph_TIM5, ENABLE);
// Configure TIM_TimeBaseStruct
TIM_TimeBaseStruct.TIM_CounterMode=TIM_CounterMode_Up;
TIM_TimeBaseStruct.TIM_Prescaler=0;
TIM_TimeBaseStruct.TIM_ClockDivision=0;
TIM_TimeBaseStruct.TIM_Period=255;
TIM_TimeBaseStruct.TIM_RepetitionCounter=0;
//initialize timer
TIM_TimeBaseInit(TIM5, &TIM_TimeBaseStruct);
//enable timer5
TIM_CtrlPWMOutputs(TIM5, ENABLE);
//set compare register values
TIM_SetCompare3(TIM5,0x00);
// start timer
TIM_Cmd(TIM5, ENABLE);
void pwmInit(){
TIM_OCInitTypeDef TIM_OCStruct;
// configure TIM_OCStruct
TIM_OCStruct.TIM_OCMode=TIM_OCMode_PWM1;
TIM_OCStruct.TIM_OutputState=TIM_OutputState_Enable;
TIM_OCStruct.TIM_OCPolarity=TIM_OCPolarity_High;
TIM_OCStruct.TIM_Pulse=255;
//initialize on channel 3
TIM_OC3Init(TIM5, &TIM_OCStruct);
//enable preload
TIM_OC3PreloadConfig(TIM5, TIM_OCPreload_Enable);
void motorDriverInit(){
if(isInit)
return;
GPIOInit();
timerInit();
pwmInit();
isInit=true;
void motorSetRatio(uint8_t ratio){
TIM_SetCompare3(TIM5,ratio);
void motorSetFreq(uint16_t freq){
TIM_PrescalerConfig(TIM5, BASE_FREQ/freq, TIM_PSCReloadMode_Update);
* motorsDriver.h
* Author: bitcraze
#ifndef SRC_DRIVERS_INTERFACE_MOTORSDRIVE_H_
#define SRC_DRIVERS_INTERFACE_MOTORSDRIVE_H_
#include <stdint.h>
#include "config.h"
void GPIOInit();
void timerInit();
void pwmInit();
// motor initilization
void motorDriverInit();
void motorSetRatio(uint8_t ratio);
void motorSetFreq(uint16_t freq);
#endif /*SRC DRIVERS INTERFACE MOTORSDRIVER_H_*/
* pwmMotors.c
* Created on: Sep 21, 2018
* Author: bitcraze
#include <stdint.h>
#include <string.h>
#include <unistd.h>
#include "config.h"
#include "deck.h"
#include "param.h"
#include "task.h"
#include "system.h"
static bool isInit;
static int prevDir=-1;
static uint8_t prevSpeed=255;
static uint8_t speed;
static uint16_t PERIOD_SLEEP_TIME_IN_MS=100;
typedef enum{
stop=0,
cw=1,
ccw=2
} Mode;
static Mode mode;
void pwmMotors(void* arg);
void pwmWrite(uint8_t ratio){
motorSetRatio(ratio);
void stopMotor(){
motorSetRatio(0);
static void pwmMotorsInit(DeckInfo* info){
if (isInit)
return;
motorDriverInit();
pinMode(DECK_GPIO_IO1, OUTPUT);
pinMode(DECK_GPIO_IO2, OUTPUT);
mode=1;
speed=255;
motorSetFreq(10000);
xTaskCreate(pwmMotors, "pmwMotors", configMINIMAL_STACK_SIZE,NULL, /*PRIORITY*/ 1, NULL);
isInit=true;
void pwmMotors(void* arg){
systemWaitStart();
TickType_t xLastWakeTime;
while(1){
xLastWakeTime=xTaskGetTickCount();
if(prevDir == mode&& prevSpeed == speed){
vTaskDelayUntil(&xLastWakeTime, M2T(PERIOD_SLEEP_TIME_IN_MS));
continue;
switch(mode){
case stop:
digitalWrite(DECK_GPIO_IO1,0);
digitalWrite(DECK_GPIO_IO2,0);
stopMotor();
break;
case cw:
stopMotor();
digitalWrite(DECK_GPIO_IO1,1);
pwmWrite(speed);
break;
case ccw:
stopMotor();
digitalWrite(DECK_GPIO_IO2,1);
pwmWrite(speed);
break;
default:
break;
prevDir=mode;
prevSpeed=speed;
PARAM_GROUP_START(xMotorPWM)
PARAM_ADD(PARAM_UINT8, mode, &mode)
PARAM_ADD(PARAM_UINT8, speed, &speed)
PARAM_GROUP_STOP(xMotorPWM)
static const DeckDriver pwmMotors_deck={
.vid=0,
.pid=0,
.name="pwmMotors",
.usedPeriph=DECK_USING_TIMER5,
.usedGpio=DECK_USING_PB5 | DECK_USING_PB8 | DECK_USING_RX2,
.init=pwmMotorsInit
DECK_DRIVER(pwmMotors_deck);
I think those are the three important files. Thanks
zhanghaijason
- Member
