[SOLVED] Two Crazyflies in the same area
Posted: Tue Jun 04, 2013 5:22 am
by memoryleak
Hi guys,
I cannot figure out (with the client), how to control two crazyflies with two seperate radios seperately. Once a client tries to connect to a Crazyflie, it automatically takes control over both Crazyflies.
This also happens, if I switch on only one Crazyflie first, and then activate the second. Each time the client that was connected before says that the client has been disconnected (since the other client connected to the flies).
Is there a way to control two Crazyflies seperately?
The setup was on two different PCs.
Re: Two Crazyflies in the same area
Posted: Tue Jun 04, 2013 5:41 am
by memoryleak
I solved it. As already written, you can simply change the cannel in the bootloader. Thank you guys.
Posted: Tue Jun 04, 2013 5:43 am
by seba
From what I know, you should program second CF setting radio channel to something different then the first one.
In CF PC Client open Crazyflie menu, select Bootloader, click on Initiate bootloader cold boot, turn on second CF. When connected it should populate Configuration with some values. Change radio channel and click on program. You should now see two CF's in connect dialog.
