ROS problem with MATLAB and public wifi
Firmware/software/electronics
flavia1394
Post by flavia1394 » Wed Jun 06, 2018 7:19 pm
Hello everyone,
I want to use ROS to comunicate Simulink and three drones Crazyflie. I have some problems using ROS with the public wifi of the University, when I type
`rosinit`
in MATLAB the error is:
 `Cannot connect to ROS master at http://172.30.152.10:11311. Check the specified address or hostname.`
I tried also to run the command at home with the private wifi and there it works perfectly, what are the reasons and how can I solve it? I need to use ROS at University.
Thank you for your answers.
flavia1394
Re: ROS problem with MATLAB and public wifi
Post by flavia1394 » Thu Jun 07, 2018 2:28 pm
I found a solution: sharing the connection of an Android mobile phone connected to the public Wifi to my computer, and it works !!! :D
Post by arnaud » Mon Jun 11, 2018 1:55 pm
Thanks for sharing the solution!
Most public wifi will block communication between clients to help secure the network, this is most likely what is happening to you.
