About Communication Problem TdoaV2
EgeYlcn
Post by EgeYlcn » Mon May 07, 2018 2:38 pm
Hi everyone,
When I was using first LPS system, I updated my Firmware to LPS system V2 ( Tdoa V2 ). When I was using the first system, there was a problem about communication the devices ( 6 anchor and tag ) and this problem still continue. ( For detailed information about the project : viewtopic.php?f=16&t=2900 )
The tag communicates with only 2 tags, although there are 6 anchors. The package I created has 3 values : Anchor,PreviousAnchor, TdoaDistDiff respectively.
How can I solve this problem ?
Thank You,
Re: About Communication Problem TdoaV2
Post by kristoffer » Wed May 09, 2018 7:28 am
It is very hard to solve this problem with the current information. I suggest that you start by installing the latest stable firmwares and check all configurations. The getting started guide should contain the required steps https://www.bitcraze.io/getting-started ... ng-system/
Please let us know the result and we will continue from there
br
Kristoffer
