Crazyflie 2.0 IMU data
sample
Post by sample »
Hi everyone,
I want to extract raw IMU data from CF2.0. For the last few days I've been using rostopic echo /crazyflie/imu to read the data. My question is: when I read data using this method do I get raw data from the IMU or the data I get has been filtered in some way? If the data has been filtered, how do I get unfiltered data?
Thanks in advance.
whoenig
Re: Crazyflie 2.0 IMU data
Post by whoenig »
This is unfiltered, but converted to the standard ROS units. However, the sampling frequency over the radio is very limited (100 Hz max), while the IMU generates data up to 4 kHz. If you really want the raw data at full frequency, you'll need a wired connection (I used a SEGGER J-LINK debugger before to stream data at full speed). Other people also experimented with logging to a uSD card.
sample
Post by sample »
whoenig wrote: ↑Wed May 02, 2018 4:39 pm This is unfiltered, but converted to the standard ROS units. However, the sampling frequency over the radio is very limited (100 Hz max), while the IMU generates data up to 4 kHz. If you really want the raw data at full frequency, you'll need a wired connection (I used a SEGGER J-LINK debugger before to stream data at full speed). Other people also experimented with logging to a uSD card.
Thank you for quick answer, cheers!
HC766
Post by HC766 »
Hi, whoenig. I saw that you said the imu in ROS is already converted to ROS units. Can I ask what's the different between ROS units and the raw imu data unit?
whoenig
Post by whoenig »
It depends on what variables you log. In this case it's just non-SI units to SI units, see https://github.com/whoenig/crazyflie_ro ... #L596-L604.
