if i want to build about crazyswarm, what needed?
NickCong
Post by NickCong »
Hi
i want to build crazyswarm about using 25 crazyflie,i read the http://act.usc.edu/publications/Preiss_ICRA2017.pdf and in the crazyswarm it using a VICON Vantage system with 24 cameras ,and in the http://crazyswarm.readthedocs.io/en/lat ... components,the components they used include 7.9mm reflective markers but not say where to buy the vicon vantage, how much about the vicon vantage if i want to build like crazyswarm? if it need cost too much, does i have another way to build crazyswarm?and does the lps can use to the crazyswarm instead the vicon?
whoenig
Re: if i want to build about crazyswarm, what needed?
Post by whoenig »
You can get a quote from VICON (https://vicon.com/) for your particular needs. We do support other mocap systems such as OptiTrack or Qualisys. Bitcraze LPS has not been tested with the Crazyswarm, yet.
NickCong
Post by NickCong »
whoenig wrote: ↑Tue Apr 17, 2018 12:10 am You can get a quote from VICON (https://vicon.com/) for your particular needs. We do support other mocap systems such as OptiTrack or Qualisys. Bitcraze LPS has not been tested with the Crazyswarm, yet.
ok,i see
thank you very much,
