Flow and LED deck combined?
liebs29
Post by liebs29 »
It seems like it might not be, but I cannot get heads or tails before I order. Is the flow deck and LED ring deck able to be used together?
Re: Flow and LED deck combined?
Unfortunately that is not possible. It might be possible to drill a hole through the led-ring for the camera to see through or connecting a neopixel ring similar to what we once did on the CF-nano. However the light from the leds might fool the optical flow sensor when it is close to the ground though. Would be fun to test!
It is not possible out of the box, but if you are prepared to modify the LED-ring (and voiding any warranties and risk breaking it) it is. Take a look at the hack (https://www.hackster.io/krichardsson/li ... one-d050af) I wrote yesterday, it shows how it can be done.
droneguy
Post by droneguy »
Hmm, that's very interesting! Great article!
Operationally, I have a question - the Flow deck uses the LeftExpansion7 (IO_2) pin and so does the LED Deck for the serial data for the WS2812B LEDs (labelled on the schematic as PWM_DOWN). How does that pin overloading work?
Images for reference...
Flow Deck:
LED Ring Deck:
In that hack I think it the front led signal line was just cut.
droneguy
Post by droneguy »
Huh... then how does the firmware handle it?
When the drivers for the flow deck and ring deck are enabled, IO_2 is still overloaded in the firmware right?
That is, the ring deck will output a PWM on the line, and the flow deck driver will implement the RESET/MOTION logic?
droneguy
Post by droneguy »
Nevermind.... I just saw that IO_2 is NOT used on the flow deck :P
Even though the schematic shows R4, R5 and R6 connected to IO_2, they are not populated on the boards.
Maybe update the schematic to reflect this?
The resistors to IO_2 are marked "NM" which means Not Mounted. I guess we can add some textual explanation on future schematic to mark clearly that these are intended to be not populated out of the box.
