[SOLVED] Noob - bootloader update and M2Blue only
Posted: Tue Dec 05, 2017 5:40 am
Just received my crazyflie2.0 - assembled and tested OK. I.e start sequence is OK.
So tried to install the s/w stack.
With crazyflie USB attached I ran latest cfc client. "cfclient 2017.06"
Using libUSB at first (installed via zadig-2.3)
Tried procedure for updating the bootloader. used the cf2_nrf-2017.05.bin to program it. Seemed to work (verify was never selectable).
When it was done I ended up with M2 flashing.
Tried again with with LibusbK and did not work.
After some reading occurred to me the zip file with internal manifest might be the proper file instead of the bin.
but programming failed - so tried using the cf2-2017.06.bin file
Now I've got M2 blue and I can't get it back into bootloader mode with a 3second start button press
What am I doing wrong ?
How can I recover ?
How can I recover ?
