(python client keyboard control)
hello i would like to control my drone via python...
so bassically take the first script from the pyhton lib using flow
https://github.com/bitcraze/crazyflie-l ... nceSync.py
so basscially i would like to use instead of having to open the cfclient and conenct with a ps2 controller i would like to control the crazy flie via terminal and pyhton with this script i tried to make..first time on python.so already learnt allot in just writting this even tho it doesnt function.
https://gist.github.com/anonymous/77429 ... a5fccfda06
so when i run the code i use python3 and it runs but does not work..my aim is for it to run like so..
start and move to hover point .4 from here on i can then controll thrust pitch and such with keyboard mapped keys?
can anyone help why this is not working?is it possible?
is there a python script that uses ps2 that i could change?
anyway thats all just started will continue..
p.s so far code runs and all left right work but if i add crazyflie code runs connects but as soon as i touche a key it closes the python3 window.
thankks
Re: python client keyboard control
infact just found this very similar...question i belive...as he is looking to do the same as me as in osx voice control a bash script into python to crazyflie?
viewtopic.php?f=6&t=2648
read it but seems i need to change firware and flash new firmware?
or can i do it just in python please please?
The script you are trying to use requires the Flow deck for velocity control. Are you using the Flow deck?
If you just want to control the Crazyflie from a terminal using a joystick I would recommend using the headless client that is in the crazyflie-clients-python repository:
$ bin/cfheadless --help
Disabling standard output for libraries!
usage: cfheadless [-h] [-u URI] [-i INPUT] [-d] [-c CONTROLLER]
[--controllers] [-x]
optional arguments:
-h, --help show this help message and exit
-u URI, --uri URI URI to use for connection to the Crazyradio dongle,
defaults to radio://0/10/250K
-i INPUT, --input INPUT
Input mapping to use for the controller,defaults to
PS3_Mode_1
-d, --debug Enable debug output
-c CONTROLLER, --controller CONTROLLER
Use controller with specified id, id defaults to 0
--controllers Only display available controllers and exit
-x, --x-mode Enable client-side X-mode
I was a bit quick and misunderstood the question, now I understand what you want to do
One issue is that you have to call the command command at least 2 times per second which I'm not sure you will be able to do using your code. I think that the event loop will lock until you press a key. Or? If that's the case I would recommend using a separate thread that send the command at at least 2Hz and send events from the PyGame event loop into that thread.
ok ok ...
how do i get a controller to work with headless?
do i just run python3 headless.py -c and plug in a usb controlerr or is it more complicated?
how would i set it to use my internal keyboard ?
as for python i am new an have no idea how to up the speed of sending commands to 2 hz any help would be good...if not im sure time will tell.
thanks
thanks
