								gpvillamil
		Posts:  2 Joined:  Sun May 26, 2013 2:47 am
						Post
								by gpvillamil  Sun May 26, 2013 3:06 am
			I picked up a Crazyflie at Maker Faire from Seeed, and the box said 10 DOF.
However, I notice that on the PCB the footprint for the compass and barometer seem to be empty. (See photo)
Is this right, or are these instruments actually somewhere else on the board?
The original image is at
http://www.villamil.org/images/crazyfli ... onfirm.JPG  so you can confirm what the box says.
								atomicdog
		Posts:  105 Joined:  Tue Mar 12, 2013 2:50 amLocation:  San Diego
						Post
								by atomicdog  Sun May 26, 2013 5:25 am
			You must be looking in the wrong area.
I see both parts.
The silver can at the bottom left (barometer) 6-DOF CF | wireless xbox 360 controller
								TheFrog4u
		Posts:  113 Joined:  Fri Feb 08, 2013 6:59 pmLocation:  Bremen, Germany
						Post
								by TheFrog4u  Sun May 26, 2013 11:04 am
			atomicdog is right, you definatly have the 10 dof version and your board looks exectly like mine..
								Redouan
		Posts:  14 Joined:  Mon May 06, 2013 7:57 amLocation:  Netherlands
						Post
								by Redouan  Sun May 26, 2013 5:22 pm
			I am sure you have a 10DOF version. You can also check out the LOG in the client, it will give you "OK" for the sensors.
								gpvillamil
						Post
								by gpvillamil  Sun May 26, 2013 11:53 pm
			OK, thanks everybody, that is reassuring!
Are the two additional sensors supported already in the client & firmware, or is it an opportunity for development?
								atomicdog
						Post
								by atomicdog  Mon May 27, 2013 12:14 am
			gpvillamil wrote: OK, thanks everybody, that is reassuring!
Their not supported in the official releases yet, but people have begun developing forks of the code that do.
You can search the forum or check out the
repo  for the code.
