Crazyradio PA firmware upgrade error
netkimjh
Post by netkimjh »
solved
Re: Crazyradio PA firmware upgrade error
The output looks correct and is seems that you are running the latest firmware available (0.53).
Do you have problems with the radio so that you feel you need to upgrade it?
netkimjh
Post by netkimjh »
solved
The error is most likely caused by a right problem, launching the command with sudo should remove the message.
Did you flash the crazyradio PA firmware?
