[SOLVED]crazyflie 2.0 m1 and m4 lights solid red, m2 solid blue
Posted: Fri Jun 30, 2017 7:03 pm
				So I was trying to fix a problem with a crazyflie 2.0 and a z-ranger deck that I know works because I've tested it on other crazyflies, and i decided to use the cold boot and flash the firmware a few times to see if that would help. The first time I flashed the firmware the M2 light was solid blue, but i'd experienced that before so I held in the button BEFORE plugging in the battery, then released when it went into bootloader mode. I did this twice - it never restarted perfectly for me - and then the last time I did it the two front lights - M1 and M4 - went solid red, while the M2 light stayed solid blue. However, this time it can at least turn off, so there's that. Anybody have any ideas? in the meantime i'm going to try and flash the firmware again.
Edit: I'd like to clarify; this was a Crazyflie 2.0, and I was using the firmware version 2017.06. I know the crazyradio PA works because it's how I got the firmware on before I tried to flash it. I know the z-ranger deck works because i've used it on other crazyflie 2.0s before.
