I installed the VirtualBox version 5.1 (newest version) and BitcrazeVM_2017.03 as on the website. Then I import the Bitcraze into the VirtualBox and click the green arrow START. However, there is an error like this:
I have deleted the VirtualBox and reinstalled but the problem still persists. If anyone has solution to this problem, please tell me!!
Thank you.
Problem when opening VirtualMachine of Crazyflie on VirtualBox
Re: Problem when opening VirtualMachine of Crazyflie on VirtualBox
This looks like a conflict problem between virtual machine supervisor. It can be caused by having an other virtual machine software installed and/or running (like vmware or virtual PC).
I have never used any Virtual Machine Software before, and I didn't find any software like you mentioned in my computer. I attached my Log file below, can you have a look to see what is the problem?arnaud wrote:Hi,
Thank you so much.
- Attachments
- VBoxHardening.log
- (10.25 KiB) Downloaded 219 times
Searching quickly on Google shows that this problem happens on windows, there seems to be a couple of procedure to fix it.
Anyway I tested the Bitcraze VM 2017.03 in Windows 10 running Virtualbox 5.1.18 and everything works fine for me, so it does not seems to be a problem related to the VM but more to windows or other software affecting Virtualbox.
