Connecting to Crazyflie while charging bricked Crazyflie
Posted: Sun May 19, 2013 11:56 am
Hi there,
I seem to have bricked my Crazyflie, although I can't figure out why.
I'd just flown my Crazyflie until the battery was down, as I've done quite a few times since I got it. No major crashes or anything occured. When the red LED was lit continuously, I stopped flying and plugged it in, and the CF started charging. I wanted to take a look at the TOC it sends to the CF Client, so I tried to connect to it with the radio while it was still charging - which I've also done before - and managed to do so.
Before I could do anything more than see that the Client could tell that the CF wasn't 100% level, though, I lost the connection due to packet loss. The CF's LEDs were still on, so I thought that it might be some kind of interference because I was charging. Therefore I disconnected the charger and turned on the CF. It turned on and the propellers turned. I tried to establish another connection, but couldn't due to packet loss again. So I turned off the CF and plugged it back into the charger.
This time, the LEDs didn't turn on and the propellers didn't turn. Since then (it's been about an hour) the CF doesn't react to anything. If I plug it into the charger, nothing happens, and if I try to turn it on without it being connected to the charger, also nothing happens. Have I bricked my CF? What can I do?
Thanks!
Daniel
Thanks!
Daniel
