LPS node failed to set dtr/rts
Posted: Mon Oct 17, 2016 3:44 am
by SlouchyCat
Dear crazyflier,
I am unable to connect to one of my LPS node and when I "dmesg", i saw this "failed to set dtr/rts" problem and i am unable to access to this node. The error is shown below:
picocom v1.7
port is : /dev/ttyACM0
flowcontrol : none
baudrate is : 9600
parity is : none
databits are : 8
escape is : C-a
local echo is : no
noinit is : no
noreset is : no
nolock is : no
send_cmd is : sz -vv
receive_cmd is : rz -vv
imap is :
omap is :
emap is : crcrlf,delbs,
FATAL: cannot open /dev/ttyACM0: Device or resource busy
Please help!
SlouchyCat
Re: LPS node failed to set dtr/rts
Posted: Mon Oct 17, 2016 11:29 am
by arnaud
What is the version of the firmware you are running in the anchors? There has been a lot of work on the USB last week so maybe you could try the dev-tdoa branch. I still have a bug to fix on this branch before merging it on Master but the USB part is working really well on it.
/Arnaud
Posted: Tue Oct 18, 2016 3:03 am
by SlouchyCat
Hi arnaud,
Thanks for the reply!
I am using lps-node-firmware from dev-freertos branch and just synced with the latest TWR tag algorithm, other anchors are okay. Its just one of them has this problem. I cannot find the dev-tdoa branch under lps-node-firmware, may i know where can I find this branch?
Posted: Tue Oct 18, 2016 5:54 pm
by arnaud
Sorry I meant dev-freertos. I am working on tdoa but it is not working yet though. I just merged dev-freertos to master so master now contains the new USB implementations.
- Have you ever been able to connect the problematic node?
- Is it possible to program it with DFU?
/Arnaud
Posted: Wed Oct 19, 2016 3:19 am
by SlouchyCat
Hi arnaud,
Yes I was able to connect to the problematic node before, and yes it is possible to flash it with DFU. However, same problem occurs even after I flashed the latest firmware ( the merged master firmware). When I try to "picocom /dev/ttyACM0", the following msg is shown:
tl@tl-desktop:~$ picocom /dev/ttyACM0
picocom v1.7
flowcontrol : none
baudrate is : 9600
parity is : none
databits are : 8
escape is : C-a
local echo is : no
noinit is : no
noreset is : no
nolock is : no
imap is :
omap is :
Terminal ready[/i]
I am still unable to access to the node setup. Please advise!
Thank you!
Posted: Wed Oct 19, 2016 7:59 am
by marcus
If the node is reset or crashes you might see something line this (got this while resetting it a few times).
[ 8241.037789] cdc_acm 2-2:1.0: ttyACM3: USB ACM device
[ 8244.865185] usb 2-2: USB disconnect, device number 63
[ 8244.865268] cdc_acm 2-2:1.0: failed to set dtr/rts
[ 8247.449871] usb 2-2: new full-speed USB device number 65 using xhci_hcd
So if I understood correctly the other nodes work with the same firmware, but this one never prints the "hello" message. What happens if you press 'h' on the keyboard after connecting? This should print a help message.
0-9 - set address
a   - anchor mode
t   - tag mode
s   - sniffer mode
d   - reset configuration
h   - This help
Linux will first try to open the device and send modem commands to it, this takes about 10-15 seconds. During this time you will the the message you pasted in the first post:
Could you wait about 30 seconds (to be sure) before trying to connect to it the first time and check if you get the message. If you don't try to connect once more and see if you get it.
Posted: Wed Oct 19, 2016 8:09 am
by marcus
One more thing. When Linux tries to check if the device is a modem it will send commands to it. Unfortunately some of these contain 1 and 0, which will reset the anchor address (I think the final state is 0). To make things easier you could disable this so you keep the correct anchor address and can open the device directly after connecting it. If you're running Ubuntu you can switch or the modem manager with the following command (until the next restart).
systemctl stop ModemManager.service
You could also disable it completely using the following command (won't start the modem manager on reboot):
systemctl disable ModemManager.service
Note that if you're using the modem manager (like for a 4G mobile modem) you probably can't use this workaround.
Posted: Thu Oct 20, 2016 2:38 am
by SlouchyCat
Hi marcus,
Thank you for the help. Unfortunately I am still getting the error message "failed to set dtr/rts" after waited for 2 mins. Disabling modem manager seems no effect to the node. When I press h also no response from console and the terminal is ready
[ 2000.303502] usb 2-4: USB disconnect, device number 10
[ 2000.303678] cdc_acm 2-4:1.0: failed to set dtr/rts
[ 2003.937601] usb 2-4: new full-speed USB device number 11 using xhci_hcd
[ 2004.066954] usb 2-4: New USB device found, idVendor=0483, idProduct=5740
[ 2004.066956] usb 2-4: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 2004.066957] usb 2-4: Product: Loco Positioning Node
[ 2004.066958] usb 2-4: Manufacturer: Bitcraze AB
[ 2004.066959] usb 2-4: SerialNumber: 1F0049000451485732303920
[ 2004.067380] cdc_acm 2-4:1.0: ttyACM0: USB ACM device
picocom v1.7
flowcontrol    : none
baudrate is    : 9600
parity is      : none
databits are   : 8
escape is      : C-a
local echo is  : no
noinit is      : no
noreset is     : no
nolock is      : no
imap is        :
omap is        :
Terminal ready
Do you have other solutions in mind?
Thank you!
Posted: Mon Oct 24, 2016 11:39 am
by marcus
Since the DFU is working and the log from production shows output from the UART I think it's a firmware issue. It might be something wrong in the EEPROM, do you have the toolchain set up? If so then do one build where you call this function to write a default configuration to the EEPROM?
