Strange wobble during flight
Posted: Fri May 17, 2013 8:21 pm
Hi folks, my copter has been experiencing a strange wobble during flight. This occurs along the axis containing motors 1 and 3. It manifests as a quick oscillation, that flattens out within a second or so. The severity of the oscillation varies, from barely noticeable to bad enough to cause a crash. In one instance, I witnessed the oscillation develop enough to where the copter rotated past vertical.
Very amusing, not super ideal.
Any thoughts on the cause for this? The copter itself is fairly balanced. I have sanded the props a bit to get them basically balanced as well. Presumably, if the issue were with the gyro, stable flight would never be possible.
Next, I will try swapping out one or both of the motors. I am thinking one of them is probably a bit weak, which starts the oscillation, and then other forces decide whether it develops into a lolzy face-plant or resumes a semblance of stability.
Has anybody else seen something like this? Any other ideas?
I will attempt to acquire video of this phenomenon this weekend.
