Doubts about Sensor values convertion and filtering
Posted: Wed Jun 29, 2016 3:10 pm
by Yaro
Hi all,
I'm tring to understand how CF firmware get values from sensor and elaborate them. I've some newbie question that I can't solve.
- In convertion between Mag values to Gauss it's used 666.7 gauss*LSB. But since precision is +/- 4800uT, from where this value come from? I've tried to convert uT to Gauss and then calculate LSB but I get: 96/16bit=1.46mG/LSB
- I've found that Acc-Gyro are filtred inside IMU with a LPF, then Accelerator output is filtred again with a IIRLPF, then again(I suppose) in complementary filter. Why filter so much times?
- Also, since LPF is active for Acc-Gyro on IMU, why not to activate also HPF for Gyro to reduce drift?
- Order to get Accelerometer values in Imu6Read is: Read, Take Bias, Filter, Apply Bias and make conversion. I can't understand logic of this. Should it be more correct if I Filter before Take Bias or Filter after I've Applied bias and made conversion?
- Also, if I filter Accelerometer values, why don't do the same for Gyro and apply a HPF, and ARW or something to eliminate drift?
It's ok even if you answer only to some of my question!
Thank you!
Re: Doubts about Sensor values convertion and filtering
Posted: Wed Jun 29, 2016 8:52 pm
by tobias
Hi Yaro,
Well to begin with the sensor reading and surrounding code is definitely a subject of improvement and I'm glad someone is looking at it. I'll try to answer your questions as good as I can.
You are probably right. I don't think the absolute Gauss value ever been validated so the scaling can definitely be wrong.
If I don't recall wrongly only the gyro should be filtered inside the MPU9250. The accelerometer is filtered outside because at one point we had different accelerometer chip and for convenience we then filtered it outside to easier switch between chips. As the accelerometer is very noisy because of vibrations the filtering helps for the stability.
Sounds like a good thing to try!
As the bias for the accelerometer isn't used and the IIRLPF isn't for the gyro it doesn't look so strange but could be arranged clearer and better.
GYRO: LPF[MPU] -> BIAS -> CONVERSION
ACC: RAW[MPU] -> IIRLPF -> ALIGN (-> BIAS) -> CONVERSION
Definitely worth a try.
Posted: Thu Jun 30, 2016 10:13 am
by Yaro
Thank you for your answers!
I've checked better about this and found that MPU setting are Initialized inside
imu6Init with this registers:
mpu6500SetFullScaleGyroRange(IMU_GYRO_FS_CFG);
mpu6500SetFullScaleAccelRange(IMU_ACCEL_FS_CFG);
#ifdef IMU_MPU6500_DLPF_256HZ
// 256Hz digital low-pass filter only works with little vibrations (high freq vibrations)
// Set output rate (15): 8000 / (1 + 15) = 500Hz
mpu6500SetRate(15);
// Set digital low-pass bandwidth
mpu6500SetDLPFMode(MPU6500_DLPF_BW_256);
#else
// Too low DLPF bandwidth might cause instability and decrease agility
// but it works well for handling vibrations and unbalanced propellers (that have low freq vibration)
// Set output rate (1): 1000 / (1 + 1) = 500Hz
mpu6500SetRate(1);
mpu6500SetDLPFMode(MPU6500_DLPF_BW_98);
#endif
I've found that to activate DLPF it's necessary to set FCHOICE_B[1:0] and ACCEL_FCHOICE_B + A_DLPF_CFG respectively on Gyro and Acc registers. But as I see only DLPF Configuration registers are setted that seems not enough, so I suppose that any DLPF are active on MPU with this configurations.
Also mpu6500SetRate(1); set both Gyro+Acc sample rate, so I tought if I have 8Khz from Gyro and 1Khz from Acc I'll never have same freq from both if I doesn't apply any filter to Gyro, that seems strange, maybe I miss something.
About HPF I've found that on MPU-9250 Register Map Datasheet, address of HPF (0x1C Acc. Register) is "Reserved", so I didn't found nothing on their datasheet.
Of course I've get this informations form "MPU-9250 Register Map and Descriptions Revision 1.4" and
imu6Init function on CF Firmware. I'm not sure if datasheet is updated or if this setting are loaded in another function of CF Firmware (or even if I understood well what I've read).
Posted: Mon Aug 30, 2021 7:03 pm
by DarkKnight
hello, what do you mean the bias of the accelerometer isn't used? Does this means that the raw data of the acceleration contains the bias? And we have to eliminate bias of acceleration by ourselves?
What does the "ALIGN (-> BIAS)" means in your reply "ACC: RAW[MPU] -> IIRLPF -> ALIGN (-> BIAS) -> CONVERSION"?
Posted: Thu Sep 02, 2021 8:47 am
by tobias
I think at some point the bias was not used for the accelerometer as it is not important for keeping a level flight and optional. For the CF2.1 the accelerometer bias at startup is taken by default.
Posted: Fri Sep 03, 2021 2:17 pm
by DarkKnight
Okay.Has the accelerometer bias at startup been compensated or not?
Posted: Mon Sep 06, 2021 11:08 am
by tobias
Yes, to a certain degree. It takes the earth acceleration vector and scales toward this. It does not do a full calibration on all axis.
