I've some dubpt on how should be eulerActual output on CF firmware when Attitude(Angle) is enable on Roll and Pitch. I've performed some test with different combination on IMU ouput values sings.
Changes in signs of IMU output values was made inside void imu6Read function in imu.c:
void imu6Read(Axis3f* gyroOut, Axis3f* accOut)
mpu6500GetMotion6(&accelMpu.y, &accelMpu.x, &accelMpu.z, &gyroMpu.y, &gyroMpu.x, &gyroMpu.z);
//Here I change IMU output sings
gyroMpu.y = -gyroMpu.y;
gyroMpu.z = -gyroMpu.z;
accelMpu.y = -accelMpu.y;
accelMpu.x = -accelMpu.x;
accelMpu.z = -accelMpu.z;
Also, changes was made in distributePower to enable correct motors, note that this will not affect eulerActual values.
No other changes was made on CF Fw code.
Movement I've performed are in order: Pitch rotation forward, back to level position, backward then Roll rotation on right, back to level position, left then Yaw with CCW movement, back to pervious position, CW movement.
I've performed the first two test with IMU on top side as default without changes on IMU signs. First test is with Acc. Biasing disabled, second with Acc. Biasing enabled.
This are result:
As you can see in the second case I've "Spikes" on Pitch; If I perform a Pitch movement with a forward rotation I've a spike in opposite direction, then Pitch slowly goes to correctly position. What amazes me is difference in Pitch and Roll output when Acc.Bias is enabled and this "Spikes".
After that I've started to perform test with IMU on bottom side since my first intention is to make CF FW works in this orientation. I've performed sign combination test only on Acc output with Gyro y and z fixed inverted to follow right hand rule.
Here's results that are more significant:
I've never seen how should be a correct output graph, but I suppose it should be the n.3 with Acc.Biasing disabled.
Note the stange thing when I activate with n.3(Gyro: -y, -z | Acc: -y, -z) configuration Acc. Biasing, Roll acts as previous but Pitch have "Spikes".
In graph n.16(Gyro: -y, -z | Acc: -y, -x, -z) I've again, as I suppose, correct eulerActual output with Acc.Biasing enabled, but if I disable Acc.Biasing with this sign configuration(n.16 Gyro: -y, -z | Acc: -y, -x, -z) I've "Spikes" on Pitch and Roll acts as previous.
n.3 and n.16 configuration are somehow related.
Strange thing is with graph n.12 where I've something what I call "Attenuation", If I change Roll or Pitch with a small rotation this values remain constant over time if I hold position but when I perform more rotation I've an "Attenuation" on values even if I hold position. Also, I've a spike when I back to level(but not when perform rotation like in other graphs).
About rateDesired in graph n.16 I've found that after after I've performed a rotation and after that back to level position, rateDesired of Roll or Pitch never goes back to 0.
I've thought that CF FW is ready to fly when you load it, so I can't find where is the error. Also I've supposed that when you enable/disable Acc. Biasing you shouldn't change also IMU output, so this is somehow strange.
Someone have tips on what I'm seeing?
Also, can someone post me correct graphs of eulerActual and rollDesired from CF with respectively Acc.Bias enabled and Acc.Bias disabled(moving pitch forward and backward then roll left and right and then yaw CW and CCW)?
Thank you for any help!
