Just a quick question for you about the camera hack, where on the jtag / bus did you solder the positive and negative from the camera? I've tried several but no luck on getting the camera to work.
Brian
Camera Hack Question
Re: Camera Hack Question
The schematic shows the pinout of the JTAG.
Can you give us some more information of what camera you intend to connect?
waltsbrian
http://www.fpvhobby.com/222-rtf-24ghz-1 ... o-set.html
that the camera and tramsmitter, total weight is 4.5g and I'm just trying to sort out where to get the power from.
I read the schematics, tried pins 16. 18 & 19 in the appropriate combinations but no luck...trying 19&20 tonight...
15 VCC Digital supply voltage
16 VCOM Battery/USB voltage
17 DGND Digital ground
18 DGND Digital ground
19 AGND Analogue ground
20 VCCA Analogue supply
Any input welcome from anyone!
Maybe you need one of this Pololu 3.3V Step-Up Voltage Regulator NCP1402
