Hello
After some work, I finally get the new brand of Python client. Here can find some remarks:
1/ Implementation of this version is completely different than former ones. Much easier: you don't have to go "su" to write modifications;
2/ all commands look correct, except LED-ring;
3/ no command for LED-ring. I have to verify my xbox360_WL_L.json file;
4/ concerning cfheadless, I only succeed to get 'Too many packets lost". This is not the case using cfclient.
Have a good night (it is now 6AM)...
Jean-Claude
[SOLVED]Test of client 2015-09-57-ge8c423f
Re: Test of client 2015-09-57-ge8c423f
Hi everybody
Some tests of the new version of python client:
1/ cannot connect to flash new version of the firmware;
2/ I take out battery connected. Surprise : LED-ring operates but not headlights;
3/ I put anew the battery in place; LED-ring cease to operate;
4/ no indication for baro and ASL values; corresponding windows are empty and greyed;
5/ can put althod on. Operates with rather small and fast oscillations.
I will test the flashing cfloader.
Bad luck: on/off sw1 switch is broken. I have to use a narrow screwdriver. Not a problem. Is it possible to buy a new switch and install it?
Perhaps my crazyf is out...
Best regards
Jean-Claude
Best regards
Jean-Claude
hI
I am now using the latest version of softwares. This discussion is no longer pertinent.
Regards
Jean-Claude
Regards
Jean-Claude
Re: [SOLVED]Test of client 2015-09-57-ge8c423f
Thanks for all you feedback Mitteau!
Sorry to hear about your switch! Yes you can buy a new one and chad wrote a blog post when he fixed one on his CF1.
Was everything OK after updating to the latest versions?
