Channel/bitrate reset from time to time
Posted: Fri Mar 11, 2016 9:46 pm
by theseankelly
I typically run my crazyflie on 2mbps, channel 0. From time to time, it resets itself to 250k, channel 80. I don't notice anything specific happening to cause this (aka, I'm not shorting out any pins that I know of, I'm not flashing firmware, etc).
Any ideas about what's going on?
Re: Channel/bitrate reset from time to time
Posted: Mon Mar 14, 2016 12:29 pm
by tobias
It sound that it is loading the default settings because of something. When it happens please check the console output in the cfclient as there might be an output of the problem.
Posted: Tue Mar 15, 2016 11:49 pm
by theseankelly
Thanks Tobias. I'll keep an eye on it. Unfortunately I'm typically flying with a devo controller and not hooked up to the python client. Next time I see it happen I'll connect via the client before power cycling, and see whether any logs are present.
Sean
