bigquad "golden" hardware
Posted: Wed Mar 02, 2016 5:18 am
by theseankelly
Hey Bitcraze
Probably going to pick up a bigquad expansion deck. Was wondering if you could post info about the peripherals (motors, escs, battery, etc) you're using to develop the software.
Thanks
Sean
Re: bigquad "golden" hardware
Posted: Wed Mar 02, 2016 9:21 am
by kristoffer
We are working on a wiki page (https://wiki.bitcraze.io/projects:crazy ... ds:bigquad) for this. Since the Big Quad deck is in "Early access" state (see https://www.bitcraze.io/early-access/), all software and documentation is not complete yet, but you are more than welcome to contribute.
Posted: Tue Mar 15, 2016 11:48 pm
by theseankelly
Hey, thanks Kristoffer. I see the 'reference design' section still hasn't been populated. Do you guys have a reference design in mind? My bigquad deck just showed up and I'd love to get some input about what parts you're using for development -- easier to swim upstream if I get the same components :)
Posted: Wed Mar 16, 2016 10:57 am
by kristoffer
I see your point :-)
@tobias do you have any input on this?
Posted: Wed Mar 16, 2016 1:55 pm
by tobias
I think the easiest might be to buy a ARF (Almost Ready to Fly) kit, e.g a 250 racer drone kit or similar and then hook up the BiqQuad deck there. The quads we have built have been from parts lying around so it is not so good to use as a reference setup.
The PWM output from the BiqQuad deck should be compatible with about all ESC that take a PWM input. The default PWM frequency output of the BiqQuad deck is 400Hz which might have to be configured lower if old ESC are used (50Hz).
Posted: Wed Apr 20, 2016 3:33 pm
by theseankelly
Should be a good start:
Your order details are:
1x #9366000061-0/79492 H-King Color 250 Class FPV Racer Quadcopter Frame (Black) (US Warehouse) = $8.31
1x #206000049-0/82992 DYS BE1806 2300KV Combo set with 16amp Opto Speed Controllers X 4 (US Warehouse) = $45.61
4x #329000341-0/92099 Gemfan Propeller 5x3 Black (CW/CCW) (2pcs) (US Warehouse) = $7.96
1x #9210000119-0/73955 MultiStar Racer Series 1400mAh 3S 40-80C Multi-Rotor Lipo Pack For FPV Minis (US Warehouse) = $16.04
1x #206000050-0/86543 DYS ESC USB Linker ESC Programmer (US Warehouse) = $5.15
I look forward to joining the 250 class...and writing a ton of CF code!
Posted: Sat May 14, 2016 5:12 pm
by theseankelly
Posted: Sat May 14, 2016 6:46 pm
by tobias
Very nice indeed!
