"Failed to attach the USB device"
Posted: Tue Mar 01, 2016 1:14 pm
by Divepit
I have just gone through the setup of the crazyflie but won't get it in the air due to an error in the VM. I get the following when I try to connect my PS3 controller:
"Failed to attach the USB device Sony PLAYSTATION(R)3 Controller [0100] to the virtual machine Bitcraze VM 0.8_1.
Failed to create a proxy device for the USB device. (Error: VERR_OUT_OF_RESOURCES).
Result Code: NS_ERROR_FAILURE (0x80004005)
Component: ConsoleWrap
Interface: IConsole {872da645-4a9b-1727-bee2-5585105b9eed}"
I'm running the VM on a MacbookPro with El Capitan installed. After connecting, reconnecting and rebooting a few times I got the controller to work for half a second, followed by the VM crashing and am now back to zero.
What to do?
Cheers!
Marco
Re: "Failed to attach the USB device"
Posted: Wed Mar 02, 2016 1:42 am
by chad
Hi Marco,
What are you using to run the VM? VirtualBox or VMWare, or something else? I'll see if I can reproduce it...
Regards!
Posted: Wed Mar 02, 2016 10:05 am
by Divepit
Hey Chad, thanks for the reply!
I'm using Virtual Box but I found the solution to the problem.
It seems that it was not a software problem or anything the like. I realised that the cable I was using to connect the PS3 controller had a loose connection so I tried a different one and now it all works perfectly smooth!
EDIT: A different cable, not a different controller.
Cheers!
Posted: Wed Mar 02, 2016 10:17 am
by Divepit
UPDATE:
Nevermind, same error again even though it worked perfectly fine yesterday... :?
Posted: Thu Mar 03, 2016 3:36 pm
by pounderboy
At first I didn't manage to use my PS3 using USB controller on my 10.10.5 OSX Yosemite using virtualbox. I gave up on Bluetooth because that seems to be a specific Yosemite problem if using Virtualbox. Anyways I couldn't get it to work.
But after trying many things I found this nice page, and installed it in the xubunto.
Now the ps3 with usb controller works fine.
Maybe it helps you too.
http://gameimps.com/ps3-controller-linux-usb-290
Good luck!
/PB
