[SOLVED] 2016-02-CF2-firmware compilation
Posted: Fri Feb 19, 2016 5:06 pm
by Mitteau
Hi every body.
Since yesterday, I use the new CF2-firmware. Looks OK.
I want to make tiny modification (on LED-ring pilot).
I get arm library.
But compilation stops :
Not a git repository...
Compilation did not raise problems with former versions of firmware.
Thank you for all.
Regards.
Re: 2016-02-CF2-firmware compilation
Posted: Fri Feb 19, 2016 7:20 pm
by chad
It looks like the addition of the libdw1000 submodule and the subsequent build step to call "tools/make/check-for-submodules.py" in support of it fails when you've downloaded a zip of the source instead of cloning the git repository.
I've submitted a bug against the bitcraze/crazyflie-firmware repository.
I suggest you clone the git repository instead of using the zip until this bug is addressed.
git clone https://github.com/bitcraze/crazyflie-firmware.git
cd crazyflie-firmware
git submodule init
git submodule update
make all
Posted: Sat Feb 20, 2016 7:47 am
by kristoffer
You can also use the --recursive switch
git clone https://github.com/bitcraze/crazyflie-firmware.git --recursive
Posted: Sat Feb 20, 2016 8:02 am
by kristoffer
We broke out the driver for the dw1000 (the new positioning system) since it is also used in the anchors and we need to share the code between the projects. Git submodules is one way of distributing/sharing libraries but there are other alternatives.
@Mitteau It seems as you have downloaded the code as a zip, and we did not really consider that when we added the submodule. What is your use case? Is git a showstopper for you?
Posted: Sat Feb 20, 2016 1:51 pm
by Mitteau
@chad @christoffer, thank you very much for your quick answer. I will test your solution this week-end. Then I will write a short report.
Presently, I simply use my CF2 to learn piloting it in a room (over a bed, because of crashes). It's not so easy!! I added the LED-ring (problems seem to be solved with the last edition of CF2-firmwate), with a slight modification (self._ledring_nbr_effects and self._ledring_effect should be initialized in FlightTab.py, to 13 and 6 respectively). I use Xbox360 wireless with adhoc input json file. My LEDring is not set through chheadless, but this is another question.
Next I will add buzzer. I planned to use analogical time command (in front of Xbox) to command buzzer for the note to be sung. For this I must enter deeper in Qt4.
Other difficulties with motor fixation and motors were solved with the help of the forum: hairs in the propellers, lowering of the axis of the motor, etc. The fixation of the motor connector P7, P8, P9, P10 is rather weak. One has been slightly moved in a crash. I use a balance to measure thrust and have an idea of the quality of the motors. Before every flight, I make a small run of the motors. If they stop simultaneously, I will have stable flight.
I planned to mount camera and GPS, to examine the roof of my house... My aim is to obtain a really stable fixed position. I read your contributions and the research papers you indicated.
Posted: Sat Feb 20, 2016 2:56 pm
by Mitteau
I apologize for Christoffer who is Kristoffer... Namely Chrstoffel is the man of some symbols of riemannian geometry. So hello everybody.
I achieved my tests.
My report will be short enough:
My system is standard Ubuntu studio 15.10 + xfce4.
In my home directory, I create a directory named "GIT", put my file giter.sh inside, written according to chad's recommendation:
git submodule init
I had to load ARM libs which was done using Synaptic with the recommended repository added.
I slightly modified LEDring pilot led12ring.c:
1/initialize ring with 0 value (according to the value written in Python client,
2/modified boat lights:black at the front, green on the RIGHT red on the LEFT and 3 white leds at the back.
then make... Firmware loaded using Python client bootloader tab.
Everything works fine.
Re: [SOLVED] 2016-02-CF2-firmware compilation
Posted: Sat Feb 20, 2016 2:58 pm
by Mitteau
I should add that Initially I did not use zip file but tar.gz
Regards
Jean-Claude
Posted: Sat Feb 20, 2016 3:02 pm
by kristoffer
OK, thanks!
