After the last Weekend I'm now having a working communication between a FRDM-KL26z-Board and my beloved Crazyflie
While it was easy to send the Copter all controlling values (like thrust, yaw, roll and pitch) my focus is now on the different parameters and the functions thereof.
The first thing i wanted to check is the Battery-Status. It turns out, that it's not as easy as the controlling. That why I'm writing this in the hope, that someone can help me.
From my understanding, to know exactly where the Battery-Voltage is stored I need to access the TOC. So first thing I need to do, is to read all Parameter-Elements as described here: https://wiki.bitcraze.io/doc:crazyflie:crtp:param
But already there a Problem emerges:
When I send the command
Port/Channel, Data
2/0, 0
But sending the command
Port/Channel, Data
2/0, 1
Port/Channel,Data
2/0, [1, 64, 106, 134, 208, 63]
Since this lead to nothing I tired to read me in some Code: Where I found:
# TOC access command
TOC_RESET = 0
TOC_GETNEXT = 1
TOC_GETCRC32 = 2
https://github.com/bitcraze/crazyflie-c ... e/param.py
This lead to more confusion since it is clearly stated, that the GetCRC32 should be command 3.
So at this point I started the CrazyFlie-Client and in it its Crtp-Sniffer. After that I Connected my Crazyflie and got all the nice data sets. Hoping to find the point where the parameters are accessed. There I had to find next mysterious thing.
In the connection-start there is a command
Now in order to get the Parameter-List with my uC, it would be great, if someone would explain how exactly I get the Parameter-List and in a further step the Parameter itself.
Thanks.
Greetings,
RomanG
