crazyflieROS GUI: crazyflie loses connection
nurinuri
Post by nurinuri »
Hi everyone,
I have a problem with my crazyflie connection. I am trying to use CrazyflieROS GUI Application but when I start the PID joystick controller and connect my crazyflie to crazyradio dongle, an error showed up on the terminal saying:
"Traceback (most recent call last):
File "/home/nuradeen/catkin_ws/src/crazyflieROS/src/crazyflieROS/driverWindow.py", line 229, in <lambda>
self.paramManager.sig_test.connect(lambda name, p: self.ui.labelTest[str(name)].setText("Pass" if p else "FAIL"))
KeyError: 'MPU6500' "
and crazyflie get connected for few minutes then get lost the connection.
any one has idea about this issue?
thanks.
Re: crazyflieROS GUI: crazyflie loses connection
Post by chad »
Hi nurinuri,
I've closed the duplicate threads you made in the other sub-forums in favor of this one in Support. Please refrain from multiple posts in different sub-forums with the exact same question (and different subject lines).
I've also edited your title to make it more appropriate to the question.
whoenig
Post by whoenig »
Hi nurinuri,
Which crazyflie ROS package are you talking about? The one here http://wiki.ros.org/crazyflie does not include a GUI (however, you can use RVIZ to visualize whatever you need.)
Best,
Wolfgang
