http://www.tomjn.com/341/crazyflie-nano ... ter-notes/
Things to note:
- I've not seen anybody mention the small A on the propellers indicating anti-clockwise, there's no need to squint at rotor blade curvature
- It's not mentioned in the instructions which way the propellers should be put on, the smooth side should go on the bottom and the etched/nobbly side on top
- Callibrate your 360 controller if its new before testing things out, I havent figured out the controls entirely, but they make a lot more sense once callibrated
- Windows 8 refuses to install the crazyradio driver as it's unsigned, you need to reboot into advanced startup and select disable driver signature enforcement before you can continue
