I have Crazyflie 2.0 setup on Windows 7 64bit using client and its working fine. I tried running through python client and it's also working fine.
But when I try to run the example ramp.py it says
[b]Connection to radio://0/80/250K failed: Couldn't load link driver: [Errno None] b'libusb0-dll:err [set_configuration] could not set config 1: win error: The parameter is incorrect.\r\n'[/b]Below is the whole error statement It is able to scan the crazyflie but not connecting
Crazyflies found:
radio://0/80/250K
ERROR:cflib.crazyflie:Couldn't load link driver: [Errno None] b'libusb0-dll:err [set_configuration] could not set config 1: win error: The parameter is incorrect.\r\n'
File "../lib\cflib\crazyflie\__init__.py", line 218, in open_link
link_uri, self._link_quality_cb, self._link_error_cb)
File "../lib\cflib\crtp\__init__.py", line 91, in get_link_driver
File "../lib\cflib\crtp\radiodriver.py", line 116, in connect
self.cradio = Crazyradio(devid=int(uri_data.group(1)))
File "../lib\cflib\drivers\crazyradio.py", line 122, in __init__
self.dev.set_configuration(1)
File "D:\Python34\lib\site-packages\usb\core.py", line 554, in set_configuration
self._ctx.managed_set_configuration(self, configuration)
File "D:\Python34\lib\site-packages\usb\core.py", line 92, in managed_set_configuration
self.backend.set_configuration(self.handle, cfg.bConfigurationValue)
File "D:\Python34\lib\site-packages\usb\backend\libusb0.py", line 440, in set_configuration
_check(_lib.usb_set_configuration(dev_handle, config_value))
File "D:\Python34\lib\site-packages\usb\backend\libusb0.py", line 387, in _check
raise USBError(errmsg, ret)
usb.core.USBError: [Errno None] b'libusb0-dll:err [set_configuration] could not set config 1: win error: The parameter is incorrect.\r\n'
