Self Test X [FAIL]
Posted: Thu Nov 12, 2015 6:53 pm
My crazyflie 2.0 when turned on no longer passes self tests. The m1 light flashes red 5 times and repeats. The output of the console tab is the following:
AK8963: Self test X [FAIL]. low: -200, high: 200, measured: 16253
So I'm assuming some acceleration sensor or something of that nature is not responding correctly. It's being turned on without any movement on a flat surface, as always.
Any help would be appreciated.
h!
CFGBLK: v1, verification [OK]
IMU: MPU9250 I2C connection [OK].
IMU: AK8963 I2C connection [OK].
IMU: LPS25H I2C connection [OK].
DECK_DRIVERS: Found 4 drivers
DECK_INFO: Found 0 deck memory.
DECK_CORE: 0 deck enumerated
EEPROM: I2C connection [OK].
I2CDEV: Error callback nr: 256
