Explanation about stabilizer.c
Posted: Fri Sep 18, 2015 7:55 pm
Hi, i want to know more about the stabilizer.c especially the altitude hold mode.
I have some question about the code, why does CF fuse the accmeter and barometer to do the althold? why not only use barometer?
and then about the code, as i read in the code, altHoldPIDVal is the output of pid value, can someone explain the formula above? because i dont get the concept of determine the output for Thrust speed.
Regards,
Justin
// Get control from PID controller, dont update the error (done above)
// Smooth it and include barometer vspeed
// TODO same as smoothing the error??
altHoldPIDVal = (pidAlpha) * altHoldPIDVal + (1.f - pidAlpha) * ((vSpeedAcc * vSpeedAccFac) +
(vSpeedASL * vSpeedASLFac) + pidUpdate(&altHoldPID, asl, false));
// compute new thrust
actuatorThrust = max(altHoldMinThrust, min(altHoldMaxThrust,
limitThrust( altHoldBaseThrust + (int32_t)(altHoldPIDVal*pidAslFac))));
}Regards,
Justin
